Information on premium cluster upgrade
R.L.K.
R.L.K.
Bristol , Tn.
ok.. If I buy a used one then (I see a lot of 2013 and 2014 models) will the TPMS work ?
To my knowledge you will need a 15 -16 cluster for the tire pressures monitoring system to display . Lots of guys have reported installing a 13 & or a 14 cluster in their 15 & 16 Ram's the TPMS did not work just dashes .
I do believe everything else works though ....maybe someone else will chime in that has personal info on this .
I know this : my 14 Ram build date of September 2013 works 100% with a 14 & a 16 premium cluster .
indiana_pilot
I found a 15 to be safe.. I can't wait to get it installed
R.L.K.
R.L.K.
Bristol , Tn.
@ Express Man , is your Rebel Mask & Lens on Backorder with allmoparparts.com ?
Express Man
No, it's supposed to come in today is yours on backorder?
Sent from my SM-G930R6 using Tapatalk
R.L.K.
R.L.K.
Bristol , Tn.
Yep just got the email yesterday
Express Man
And delvivery changed to tomorrow now
R.L.K.
R.L.K.
Bristol , Tn.
Ronnie, when you get it post some pics of just the lens and mask, and then with it installed on the cluster.
Will do Sir !
I plan to add a step by step how to change the lens & mask assy with lots of pictures .
If there's room I'll be adding it to my OP , if not I'll do it at whatever post this thread is at here .
I'll likely be posting another link ( to here ) over on the cluster upgrade thread as well .
CuylerTech
NH
2015 Big Horn Mega Cab 4x4
6.7L
Express Man or RLK, either of you have the PN handy for the rebel mask/lens?
mpicc84
North Eastern, PA
Other then the FS threads here, is there a source for these? Also whats the average cost on the cluster themselves and having them hours / miles changed on them? This is one of the nicest upgrades we can do to our non-fancy trucks lol
stimpy433
IOWA
Hey RLK will the lens from a standard speedo work on the premium cluster??? I found a cluster locally but the lens is scratched up....
R.L.K.
R.L.K.
Bristol , Tn.
I'd say , no .
I'll have to look more closely, but the lense and the mask aka gauge accent rings are one assembly ; therefore the guage placement would have to be exact . I'm pretty sure they are not the same .
I will verify this next week when I complete my swap with the premium cluster and install the Rebel lens and Mask on it , I'll compare to my 3" cluster mask and post that info up as I plan to post up a short ( how to ) on the lense and mask change .
00R/T
CT
It will not. You'll need a lens from a cluster with the 7" TFT.
R.L.K.
R.L.K.
Bristol , Tn.
Lots of folks get a used premium cluster from carparts.com , a local salvage yard from a crash & LKQ .
I've seen premium clusters as cheep as $95 and as much as $500 ish ....kinda the luck of the draw , I'd say the average price is 300 + - a bit .
The cost of having the hours & mileage is $175
I recommend doing some reading on the Premium cluster Upgrade Thread here Sir .
http://www.ramforum.com/showthread.php?p=876612
Express Man
Anybody know part number on the ignition ring mine is silver right now and would like a red rebel one. I'm guessing it just pops off?
00R/T
CT
The Rebel has the same one. It isn't red.
KAKA
