2013 ram 1500 TPMs display on dash shows all dashes.TPMS Light on. No TPMs Codes on scan tool. Scan tool shows proper pressure!
Colin7761
Ns
Got a 2013 ram 1500. It had the premium cluster. I swapped the premium cluster into my 2014 and swapped the 2014 3.5 dash to the 2013. Is it possible that the 2014 cluster won’t read the 2013 TPMs system. I am aware that the 2013 and 2014 have a dofferent TPMs system. The premium one works in my 14. but the 14 cluster isn’t showing tire info on the 2013.
When I connect a scan tool to the TPMs computer it shows no faults and it shows the TPMs sensors are connected and displaying the proper pressures.
I can’t confirm the premium eVic displayed tire pressures as I replaced the sensors after the dash was switched. Any input appreciated. Thanks!
C
Colin7761
Ns
Tire control computer shows no faults. Cluster shows u0127 lost communication with tire pressure module.
C
Colin7761
Ns
So at this point it seems the cluster is trying to communicate with the 2014 tpm system and not the 2014. Anyone have a fix?
Ken226
Washington State
I've seen quite a few threads here over the years with this issue. Usually when someone tries to upgrade a 2013, 3" evic to the premium cluster, with a eBay unit out of a 14+ truck.
I think most have ended up getting a 2013 cluster in order to get the TPMS to show the pressures.
I haven't yet heard of anyone figuring out how to get a 2014+ cluster to show the correct TPMS data in a 2013 truck.
C
Colin7761
Ns
Thanks I appreciate the reply! The only issue I have is, I checked the log history on the premium original cluster. Sure enough, it had the u0127 code present as well. Anyone have any wiring diagrams for the cluster or C can bus system!?
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
As Ken mentioned, You need to get a 2013 cluster for the tpms to work. The tpms module is a separate module near the left front foglight and not part of the rf hub like 14+ trucks.
TMFMK
