Installing mufflex14
omega88
Was it hard? Any surprises? Did you have to cut anything? What was the hardest part? Going on a 2012 ram 1500
Thanks guys!!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
easy.
just getcha some lube (WD40) and soak the bolts. should come right off.
no cutting!
omega88
omega88
Thanks JJ!
1500ram12
5.9L Cummins
A little tip, use a ratchet strap to help pop the muffler from the pipes
Sent from DROID RAZR MAXX using Tapatalk
quietpeen
2021 TRX
Hellcat
Personally I had a hell of a time getting the stock muffler out. If you can get a buddy to help it will make things a lot easier
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I did mine at 500 miles. it was cake. :D:D
omega88
omega88
It's on!!!! Man am I glad I got the 14!!! Hardest part was loosening the stock clamps. Went in pretty easy, and man does it sound good!!
LB3711
Trumbull, CT
3.6L V6
Just replace the 3" clamp with a different style. It will loosen up.
Pics? Is it a bolt in?
Sent from my SPH-D700 using Tapatalk 2
Edgethis
Bluefield, WV
The mufflex is 100% bolt on. I really want to do this but I'm afraid of getting drone in the cab. Is the drone only an issue when MDS kicks in?
omega88
omega88
The drone is nothing. I was freakin about it, but its hardly anything.
