Instrument cluster upgrade
Ram Head
Portland
I have a 2016 ram big horn with the 3.5in screen and I want upgrade to 7.0in screen and was told I couldn't.
1500ram12
5.9L Cummins
A dealer most likely won't and it's not a part you can order from a Mopar parts dealer. But yes you can. Search in car-parts.com or local pick and pulls. It's a direct plug and play swap. You'll want a 2014-2018 cluster. You'll need to have it programmed to match your mileage and hours. There are a few companies that can do it, a member on here has the capability or alphaobd ($49 app in Google play store) paired with the obdlink mx bluetooth obd2 reader (~$60 Amazon)
2018 Ram 2500 6.4L Hemi Tradesman
R
Ram Head
Portland
Thank you I have a alfa obd and obdlink mx I will go to car-part.com and once again thank you.
KiloHotel
One of my favorite upgrades ive done to this truck! I paid about $300 for mine on this groups for sale section.
R
Ram Head
Portland
I got my upgrade instrument cluster yesterday open the box I was disappointed it was the wrong one it was 3.5" not the 7" have to send it back and get my $150 back and go searching for another one.
R
Ram Head
Portland
I have a stupid question so please bear with me I new to this stuff I want to upgrade my rearview mirror from manual dimming to auto dimming can I do this with obdlink mx with alfa obd?????
Ricks Ram
Yes you can install an auto dim rearview mirror and enable the code with the Alpa tool. You can also install the Auto dim/auto high beam mirror. We have pretty much figured out every option on the 4th gen. Depending on what options your truck currently has you may need to install a new mirror harness. If your truck came with the RA2 or higher radio you should have the correct harness already.
firehawk618
Seattle area
As others have said it will plug and play however it will not be 100% perfect.
I can't speak from first hand experience as to what exactly will not work correctly but due to coding in various modules in your truck vs whatever year cluster you get you will have varying levels of compatibility.
All the important stuff will work though.
R
Ram Head
Portland
Yes I have a RA2/Ucounect and I do have a auto dim/auto high beam mirror with assist and 911 buttons on it. What do I need to look up on Alpa tool.
Ricks Ram
Are you sure you have an auto high beam mirror? They are listed incorrectly all the time. For a guide to enable the correct mirror codes refer to the first post in the Alfa thread under (Known Working Codes) and follow the directions there. This is a pic of an Auto Dim/Auto High Beam mirror. If you don't have the camera looking lens like the one in the pic it's not an Auto Dim/Auto High Beam mirror it's just a standard Auto Dim mirror which is also fine. Since you have the RA2 radio the soft button to turn the Auto Dim on and off may not appear like it does on the RA3 and RA4 8.4" radios but it should turn on by default. 5b23157ea6802531b5e5d743d40d5ded.jpg
R
Ram Head
Portland
I have the auto dim mirror only.
R
Ram Head
Portland
All I have is auto dim mirror where do look in alfa obd to turn it on??
Ricks Ram
A list of all the known working codes and how to activate them is listed in the first post of the Alfa OBD thread. This is a pic of the code for the auto dim (Electro Chromatic) mirror. You can also install auto dim side mirrors if you have the auto dim rear view mirror. fbe703ff350fad0fbb2ea01997f6ed88.jpg
1500ram12
5.9L Cummins
Will this work on a 2009 Ram 1500? I to was told I can't, and I have the 3.5" EVIC display.
No. 13+ clusters won't work in 09-12
