Intake manifold
crgcrg
hemi 5.7 l V8
So I stupidly bought a 2003 dodge ram 2500 Laramie 5.7L V8 pickup from a used car dealer. Throttle light and engine lights came on. Took it in to local dodge dealer to have it looked at. Throttle is due to leak in intake manifold. They want 2700 to fix it, haven't diagnosed exact cause of engine light yet - it is an e-vap code. Tried to see if I could find a manifold online - don't want to spend 1000 for an edelbrock and can't figure out what would fit without needing modification. Anyone know where I can get reasonably priced manifold that will fit?
HemiLonestar
Navy Badge Coast Guard
MD
I'm leery of the Dormans, they seems to function well enough but I saw one where they didn't copy the oil fill and vent tube correctly on the LX version and every time the guy put oil in he ended up filling his air filter box. They're not quite exactly the same.
Stock
Screenshot_2020-06-17 2004 05 06 07 08 DODGE RAM 1500 2500 RAM DURANGO 5 7L Hemi Intake Manifold.png
Dorman
It would seem they did the same thing with the Ram manifold.
C
crgcrg
hemi 5.7 l V8
OK Thanks I'll have the mechanic check it out
Karlsweg
SW Florida
254B15B4-0DB0-4256-855E-021C6A9E28E7.png 6DA3A768-F709-4A21-BC96-D4D862532AB9.png Okay here’s the factory one and a part number . Maybe Canadian dodge dealer can get it if they won’t ship to you.
Saltillo Express
Man your evap code could be the gas cap. And what are they saying specifically about the manifold? Could it just be the manifold gasket?
Runaround
Silsbee
Have you checked Rock Auto?
Oops I forgot you said you fixed it.
Tray Burge
On the porch
E-vap code could also be the gas tank filler neck.
The 03's apparently have an inherent issue with the filler neck cracking causing a CEL/E-vap code too.
Ask me how I know?
HemiLonestar
MD
You mean the ten individual intake port, oil fill and PCV o-rings lol?
SxKhYWtSPEa_H8gM0QFdSPcA1NKa2L-o05ZD2HZ415r06Onk3SoNoQjeiS1F1wYrUMhDFvb_h5L0rEUfil-CDLI7yrGg31LayQ
