Husky X-act Contour Floor Mats
Grab the mat, fold it over the rear floor hump and open the floor storage lid .
Another great thing about these mats is how I do not slide around, when my boots are covered in whatever. They grip much better than my buddy's Weathertechs.
NOTE: my black mats are pretty black, just slightly less dark than my black carpet.
The pics have been highlighted, so everyone can see the mats, better.
Color is not accurate.
Now, take another look at the above image.
Notice that lifted edge, on the left side of the mat?
Runs across the open door sill?
That edge allows the mats to hold a ton of water and gunk.
If anything should get over it, which has not happened yet, the liquid just goes out the door,
Here is a closer look. that notch by the gas pedal is perfect for my foot.
FYI, I am a Railroad Engineer. You can't begin imagine the stuff I haul in, on the bottom of my Industrial work boots.
the rear floor mat is one piece. Notice how it too has a high edge, along the side, to hold in liquids?
These are called the X-Act Contours and they meant it!
Notice how well it fits.
Front passenger side Mat
See how the floor Hooks go underneath the mat?
No Holes for anything to drain through, onto the carpet.
Real important, for me. Could be gunk on the ground, year round, where I work, not to mention, all the darn Snow.
Best thing about these Mats? There are pretty pliable, for being so thick and I can easily take out a Mat, full of watery Goo and dump it on the ground. Not my Carpet.
MOPAR OEM Part # CEC1MO71AA Under Hood Light Kit -$20
Seems this was a recall parts 'kit" , not a for retail sale kit, Chrysler whipped up for 2011-2013 Sport trucks that did NOT come with the under hood & glove box lights, but should have.
The kit includes the under hood light assembly, with bulb. One push pin, to mount the light to the hood itself, 2 replacement retaining clips, for the under hood mat, the wiring harness AND one glove box light assembly.
Just pop off the two clover leaf looking clips holding the under hood mat to the bottom of the hood. ( I got by with just popping of the one but the kit comes with two new clips).
Slide the mat from underneath the retaining thingy.
Remove the bulb from the light assembly.
Mount the light assembly, with the included push pin.
When mounting the light, have the "plug in" End of the light assembly pointing up.
You can't mess it up, there is a hole and a slot, on the hood, that matches up with the back of the light itself.
Plug in the wire harness. It has two ends but only one end of it will fit the light assembly itself. It's Gofishn Proof.
Wrap from top, down the side of the mounted light assembly.
You will notice clips, on the wiring harness.
Those clips match up perfectly with holes in the hood.
Just follow them along to the hood support.
Took me about 5 minutes to do it.
Getting the bulb out of the light, so I could mount the assembly to the hood,
took me longer than anything. Was worried I would break it.
Remove the Blank Filler plug, from the electrical connector you will need.
Plug in your new light.
I was not really that impressed with the amount of light the OEM bulb gave me.
Even at night, it was Weak, Whimpy, Whambly, Whombly. So I replaced it with this one.
Got it here.
https://www.superbrightleds.com/mor...us-bulb-1-smd-led-festoon-44mm-car/1264/2937/
