Interior swap
Courtlow
Pa
I put a 20/20 Laramie 2500 interior in my 2021 tradesman and now the airbag service light is on I was wondering if anybody could help me out with figuring out what's wrong any info would be appreciated
Did you pull the battery before swapping out anything with an electrical plug?
You'll need a scanner to see what's causing the airbag service light. AlfaOBD can read and clear codes, you'll also security gateway bypass.
C
Courtlow
Pa
Yes I disconnected the battery
C
Courtlow
Pa
These are the codes that came up how would I go about fixing this
They're all codes for the passenger seat, there probably a problem with one of the wiring connectors. Probably one or more of the wiring pin connections are not making good contact causing the faults.
C
Courtlow
Pa
I think I have it figured out I pulled the seat back out and was looking at it looks like it's missing three sensors compared to the 21 seat going to try swapping those sensors over and pin those into the plug see if that fixes the problem
olyelr
Kewadin MI
So the 2020 laramie seat has 3 less sensors than the 2021 tradesman?
Hope you get it sorted out, post up pics when done !
C
Courtlow
Pa
I got the passenger seat all figured out My other issue is I watched a video on YouTube about programming to get the heated and vented seat functions to work and I can't get the soft keys on the screen to populate would anybody on here be able to help me out with that
aimcgma
