Rmck85
Ok, I thought I had the problem solved and I was wrong. I've been searching for the solution and no luck. I get an intermittent vibration around 70. Whole truck is shaking. Sometimes it's more violent than others, and sometimes it is completely smooth. I have replaced front axle u-joints, front hub bearings, front brake system, rear wheel cylinders, drums, lines, balanced tires, checked alignment, checked front end, everything is tight. I have checked front shaft u-joints and rear shaft u-joints, they are in good shape from what I can tell. I have replaced trans mount.
I notice when I start from a stop, I sometimes feel a little hopping. Thinking that may be in the trans? Could it be my transmission or my transfer case?
Thinking back, my brother and I went to the poconos to do some atv riding. I'm not pulling a lot of weight, a single axle trailer under 1500 lbs and a 500 lb atv in the bed. I was running in OD. The OD off light came on, smoke started blowing out from truck. The atf was blowing out vent tube to exhaust and dipstick was high. I let truck cool down, drove rest of trip with OD off and was fine.
I just replaced plenum gasket, intake gaskets, valve cover gaskets, complete tune up, water pump, tensioner, idler, radiator, and hoses. I'm towing my 1500 lb trailer, empty bed, and I have my scanner monitoring trans. Running in OD, my trans temp climbed to 220 so I turned off OD. Truck at 70 running at 3000 rpms but got temp to drop down to 174. When I bought truck back 2 years ago the gov press switch and solenoid were bad so replaced them. Trans left limp mode and shifts since I did that. Sometimes it feels like it downshifts too soon, sometimes not soon enough. The scanner shows target pressure and actual, and they don't seem to be matching when I check. Not sure if that is normal. I used mopar parts, atf4, and filter.
I see many people have had this vibration issue, and many pages I have come across do not have the fix. I'm worried about whatever it is causing a catastrophic event or leaving me stranded. I need to solve it.
So before I spend thousands sending out my transmission, transfer case, and drive shafts, can anyone tell me if they were able to solve this problem and what was causing it? Could it be the torque converter or clutches slipping? If I floor it on a straight away I don't feel any slippage and shifts are tight. Is there something I'm overlooking?
