Learylax3r
I've been having an issue lately with my truck starting, or rather not starting, intermittently and I'm looking for some advice on what to try.
The truck is a 17 1500 big horn 5.7. Original battery, not push to start, does have remote start.
About a month ago, I replaced the head. When restarting the truck after the job, I pulled the fuel pump fuse, to get some oil moving through before full start. Cranked it a few times, oil moved well, started and ran fine. The next couple days, I had an intermittent start issue where I would get a single click with no crank on the first start attempt, but the truck would start and run fine on either the second or third attempt. After a couple days, the truck started and ran as normal, started on the first key turn every time.
Fast forward to this week, and the intermittent start issue is back. Sometimes the truck starts on the first key turn, sometimes it starts on the 4th or 5th. Never cranks, just clicks once. Then this morning it just didn't start. Clicked once each key turn for about 10 cycles. Battery gauge was just under the mid line, which I assume is 12v. Asked a friend for a jump, truck started on the first turn of the key while being jumped.
I plan to go to the auto parts store and have the battery tested today, and will likely be either replacing that, or getting a new starter relay and trying that.
My questions are:
Why would a low battery cause a single click several start attempts, but start fine several attempts later without seeming sluggish or dimming lights while trying to start?
If it was the relay, why would it start right up the first try while jumping the truck?
Does anyone have any other ideas of what else this could be?
My questions are:
