No, the truck is not running right with an issue I first posted
here nearly two years. Been to different dealerships multiple times and they have not been able to isolate or fix it. The truck has gone into "limp" mode while driving numerous times, throwing a "Check ETC" light and P2122 code. When that happens the truck is stuck in 3rd gear until I stop and re-start - after which it runs fine again until the next episode, sometimes >6 months later! It's nearly impossible to diagnose something that is THAT intermittent.
I have replaced the Accel Pedal assembly; checked the wiring; run numerous DTC scans, etc., to no avail. The last time I took it to the dealership they had it for 2 weeks - and found nothing wrong.
I am now starting to think that maybe this is a TRANSMISSION issue, not APPs. The problem always occurs under the same condition - foot off the gas and coming to stop at intersection, stop sign, etc. In other words, when the truck is coasting down or has just come to a stop.
A couple of times while sitting at an intersection I felt like I was bumped from behind - but there was no one behind me. So the transmission, it seems, is shifting or doing something weird when it shouldn't be doing anything.
The PCM has also stored several U1428 codes - "Invalid Torque signal" - which is why I am now suspecting the transmission may be the cause of this.
All of this begin a few years ago when my battery went dead and had to be replaced. The truck was jump-started prior to the new battery. I am thinking MAYBE there was a voltage spike that messed up the PCM/TCM software and that, perhaps, a re-flash would fix. IDK Everything seems to be a guess at this point.
