Is speedometer gear driven or electric?
Nick_rp
I=V/R
puyallup, wa
5.7 Sport
Like title says.
I have an intermittent needle lag between 15-45mph.
Thanks
2012 ram sport 5.7
muddy12
Indiana
Pretty sure it’s electronic.
I had similar symptoms on a 99 that I used to have. Turned out to be contamination (metal particles) on the rear axle speed sensor.
However, I’m not sure where the sensor is on the 4th gens.
circuitguy
Elk Grove, CA
2017 Ram Tradesman Regular Cab
5.7L HEMI
The complete gauge cluster is electric. You could have a bad speedo stepper motor in the cluster, this is what makes the needle move up and down. This happens often on older trucks.
Nick_rp
Nick_rp
I=V/R
puyallup, wa
5.7 Sport
Sweet sounds easy thanks for the input.
McBroom
Denison Tx
Hemi 6.4L
^^^X2^^^ I it is electronic because they have to use a computer to adjust it. Mechanical would involve going under and changing the drive gear in the tranny
Blue Streak Pearl off-road
