Is the OEM "Alpine" R/T system amplified?
UNBROKEN
2012 Ram R/T
I'm looking into interfaces between the head unit and my Mosconi 6to8 processor...the ones I see are for a stock amplified system.
If I can do plug n play that'll make wiring a lot easier. If not we'll have to isolate the speaker wires and solder RCA's to them for an input signal.
kkreit01
Olathe, KS
If it's a factory Alpine system, it has an amp. It will not have RCAs.
UNBROKEN
UNBROKEN
2012 Ram R/T
Adding RCA's to speaker wires for a high level input is easy...using the plug n play PAC adapter is easier. lol
Thanks
audio1der
Airdrie, Alberta
I recognize you know your stuff, but make sure the Mosconi can handle that kind of input!
I used an old (home)stereo receiver to power the bass shakers in my couch, and put RCAs on speaker level outputs from my main amp for signal. It lasted 3 months before almost 7V of signal fried it, but HOLY GOD while it worked!:ryu-cvs-hadoken-a:
UNBROKEN
UNBROKEN
2012 Ram R/T
The 6to8 DSP is made specifically for installs like this. You switch between high and low level input via the same RCA inputs.
