BAKFactoryOutlet
- Mar 15, 2013
- 76
- 8
- 2007
- Hemi 6.1
If you’re searching for a tonneau cover or bed cover for your Ram truck (with or without the RAM Box), any of the BAKFlip models would an ideal choice. Not only is the hard folding function practical, it is Secure! The sleek design of the BAKFlip allows it to sit between the side rails giving a flush look, unlike those bulky Over-The-Top hinge covers. There are 5 models of the BAKFlip: G2, HD, Fibermax, F1, and VP. The BAKFlips are made of either aluminum panels, fiberglass panels or even with nice smooth vinyl top.
Now if you’re interested in a Roll Cover BAK has recently released their Roll-X Hard Rolling Tonneau (Not available for the Ram Box). It features a sleek, smooth Vinyl top with an impenetrable Aircraft Grade Aluminum underside. The rail system has also been set up with an awesome security feature, when rolling the cover shut the latch mechanism triggers an inner rail to lock down the ENTIRE cover. Also since the cover rolls up, you have an unobstructed rear view. It is a great addition to the BAK Family, and truck beds of the world.
So if you’re in the market for a tough, water-tight, yet classy tonneau cover, give us a call!
(800)653-7089 ext. 706
Or Visit our Website! BAK Factory Outlet
Mention this ad and promo code: “drew15” to get 15% off your entire order!
BAKFlip: Hard Folding Tonneau Cover
G2
FiberMax
HD
F1
CS:You can upgrade the Fibermax, HD or F1 with the CS Ladder Rack System.
VP
Roll-X: Hard Rolling Tonneau Cover
RollBAK: Hard Retractable Tonneau Cover
-Drew
www.BAKFactoryOutlet.com
“Home of the BEST FLIPPIN’ Cover!”
G2
- Aluminum Panels w/ 2 lbs EPS Insulated Foam Core
- Aircraft Grade Aluminum Panel Frames
- Rounded Style Corrosion Proof EPDM Rubber Hinge
- 400 lbs (Evenly Distributed) Weight Rating
- Corrosion Proof EPDM Rubber Side Seals
- 1 Year Warranty
- Only available in a Textured Powder Coated Black Finish
FiberMax
- FRP Fiberglass Top, Aluminum Bottom panel w/ 2 lbs EPS Insulated Foam Core
- Flush Style Corrosion Proof EPDM Rubber Hinge
- 2 Year Warranty
- Only available in a Black FRP Fiberglass Finish (with a Hair Cell Texture)
HD
- Aluminum Panels w/ 3.5 lbs EPS Insulated Foam Core
- 450 lbs (Evenly Distributed) Weight Rating
- 2 Year Warranty
F1
- FRP Fiberglass Top, Aluminum Bottom panel w/ 3.5 lbs EPS Insulated Foam Core
- 500 lbs (Evenly Distributed) Weight Rating
- 3 Year Warranty
- Stainless Steel Rack Uprights
- Aluminum Cross Bars
- 500 lbs Weight Rating
- 2 Year Warranty
- Only Available in a Smooth Black Powder Coat Finish
VP
- Aluminum Panels w/ 2 lbs EPS Insulated Foam Core Covered in Vinyl
- Seamless No-Hinge Design
- No Weight Rating (Not recommended putting weight on top)
- 1 Year Warranty
- Only Available in a Smooth Black Vinyl Finish
- Interlocked Aircraft Grade Aluminum Slats Adhered w/ Vinyl
- 1 Year Warranty
- ABS Plastic Canister w/ an Aircraft Grade Aluminum Lid
- 2 Year Warranty
- Only Available in a Smooth Power Coated Black Finish
-Drew
We love seeing Happy Customers!
