Is your Bed Secure?!?
Hemi 6.1
If you’re searching for a tonneau cover or bed cover for your Ram truck (with or without the RAM Box), any of the BAKFlip models would an ideal choice. Not only is the hard folding function practical, it is Secure! The sleek design of the BAKFlip allows it to sit between the side rails giving a flush look, unlike those bulky Over-The-Top hinge covers. There are 5 models of the BAKFlip: G2, HD, Fibermax, F1, and VP. The BAKFlips are made of either aluminum panels, fiberglass panels or even with nice smooth vinyl top.
Now if you’re interested in a Roll Cover BAK has recently released their Roll-X Hard Rolling Tonneau (Not available for the Ram Box). It features a sleek, smooth Vinyl top with an impenetrable Aircraft Grade Aluminum underside. The rail system has also been set up with an awesome security feature, when rolling the cover shut the latch mechanism triggers an inner rail to lock down the ENTIRE cover. Also since the cover rolls up, you have an unobstructed rear view. It is a great addition to the BAK Family, and truck beds of the world.
So if you’re in the market for a tough, water-tight, yet classy tonneau cover, give us a call!
(800)653-7089 ext. 706
Or Visit our Website! BAK Factory Outlet
Mention this ad and promo code: “drew15” to get 15% off your entire order!
BAKFlip: Hard Folding Tonneau Cover
G2
  • Aluminum Panels w/ 2 lbs EPS Insulated Foam Core
  • Aircraft Grade Aluminum Panel Frames
  • Rounded Style Corrosion Proof EPDM Rubber Hinge
  • 400 lbs (Evenly Distributed) Weight Rating
  • Corrosion Proof EPDM Rubber Side Seals
  • 1 Year Warranty
  • Only available in a Textured Powder Coated Black Finish
FiberMax
  • FRP Fiberglass Top, Aluminum Bottom panel w/ 2 lbs EPS Insulated Foam Core
  • Flush Style Corrosion Proof EPDM Rubber Hinge
  • 2 Year Warranty
  • Only available in a Black FRP Fiberglass Finish (with a Hair Cell Texture)
HD
  • Aluminum Panels w/ 3.5 lbs EPS Insulated Foam Core
  • 450 lbs (Evenly Distributed) Weight Rating
  • 2 Year Warranty
F1
  • FRP Fiberglass Top, Aluminum Bottom panel w/ 3.5 lbs EPS Insulated Foam Core
  • 500 lbs (Evenly Distributed) Weight Rating
  • 3 Year Warranty
CS:You can upgrade the Fibermax, HD or F1 with the CS Ladder Rack System.
  • Stainless Steel Rack Uprights
  • Aluminum Cross Bars
  • 500 lbs Weight Rating
  • 2 Year Warranty
  • Only Available in a Smooth Black Powder Coat Finish
VP
  • Aluminum Panels w/ 2 lbs EPS Insulated Foam Core Covered in Vinyl
  • Seamless No-Hinge Design
  • No Weight Rating (Not recommended putting weight on top)
  • 1 Year Warranty
  • Only Available in a Smooth Black Vinyl Finish
Roll-X: Hard Rolling Tonneau Cover
  • Interlocked Aircraft Grade Aluminum Slats Adhered w/ Vinyl
  • 1 Year Warranty
RollBAK: Hard Retractable Tonneau Cover
  • ABS Plastic Canister w/ an Aircraft Grade Aluminum Lid
  • 2 Year Warranty
  • Only Available in a Smooth Power Coated Black Finish
-Drew
www.BAKFactoryOutlet.com
“Home of the BEST FLIPPIN’ Cover!”:Rock on::favorites37::grd:
chuck
Maryland
2013 True Blue Big Horn
Those look really sleek, I'll be considering one when I do purchase a bed cover.
Sent from my iPhone using Tapatalk 2
thrashie
All Over
2013 2500 Laramie
6.7l cummins turbo diesel
got any that work with the tracrac rails? non g2
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I freakin' love my backflip.
ZCR
Summerset, SD
2013 Longhorn 4x4
5.7 Hemi A8 3.92
Very nice, but I'm looking for a roll-up for the Ram Box.
BAKFactoryOutlet
Hemi 6.1
The problem with Roll-up covers on a Ram Box is that most roll-ups have a bulky rail system that causes leaks most of the time. I would highly recommend a Hard cover to secure from intruders and/or the elements.
"Soft Roll-up Covers are a :badidea:"
-Drew
reddot
Wolf Point, MT
5.9 cummins
can you get the roll-x in custom lengths, and could it be sealed against a tool box?
BAKFactoryOutlet
Hemi 6.1
Also as a reminder, we carry TracRac systems that work with our Roll-Up and Retractable covers. Plus an assortment of sport equipment carriers for the BAKFlip Rack System. So if you're heading to the river this summer, you'll need kayak racks. If you're heading to the mountains, you'll need some bike racks.
Remember:" We got you COVERED!"
-Drew
(800) 653-7089 ext 706
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Is your bed secure?
Why yes, yes it is. I believe its bolted on.... :party33:
Sorry, couldn't hold it back. :rockit:
quietpeen
2021 TRX
Hellcat
i am also a huge fan of bak-flips. On my second one now
