Razzaa
- Aug 10, 2013
- 860
- 186
- 2013
- Hemi 5.7
Had 2x10" JL TW1's installed last week but I have an issue with my amp shutting off. Amp is a Kenwood XR 900-5. It shuts off when I turn the volume up high. It doesn't get hot at all and should easily be able to handle my set up. Both subs are running in parallel @ 2ohms. The sub channel is rated for 600w RMS @ 2 ohms. My Subs are rated 300w each @ 2ohms. All power coming into the amp reads where it should. The Ohms reads perfect as well.
The only way I have been able to get the amp to not shut off is by turning the gain way down. Anyone else have a similar issue? Do you think it is a problem with the amp internally?
