1 7/8 primaries are probably too big for a stock engine right?
Yea, 7/8 JBA long tubes are what people have recommended to me on here as well so I assume they fit fine.
So, if one were to buy the 7/8 JBAs and their Y-pipe, would everything just bolt up fine without having to weld or modify anything? It would great to actually be able install these in the garage instead of having a shop do it.
That's the first person I've heard of having any fitment issues actually.
Many of those that don't know they have fitment issues have more false knock issues then you can shake a stick at.
Later finding the issue they had no clue was there after I tell them to check...
I know this is an old post but I didn't wanna start a new thread for a few questions. I purchased the jba long tubes and ypipe for my 13 4x4.
Anyone know the torque specs for the headers? Also should I use the bolts and gaskets that come with them? If not which brand is the best? Any tips or tricks besides the oil dip stick needing to be bent?
Finally breaking some good weather in the north east and I can finally install them. It's been crappy staring at them over the past two months and not having installed on the truck.
Thanks!
Good-n-tight,lol. Odds are you won't get a socket on a few of them anyways. Gear wrenches make the job a little nicer. Make sure you re-install the dipstick before you bolt the drivers side header in tight. The bottom dipstick bolt can be a pain to get at and remove.Use the OEM gaskets from the dealer or Remflex gaskets. Good chance you'll end up denting the driver side header to clear the steering shaft,trial fit the header then dent it where it's closest to the knuckle. The motor mounts are soft on these trucks and allow a fair bit of engine movement,so even if it looks like you've got clearance,i'd still dent the one tube ,as they aren't the easiest thing to get at when installed. Buy beer it'll help,lol.
