Just another tire question
Lazaro713
Houston Tx
You might rub when turning because of the offset and how wide the tire is. Right now Im rubbing on 35x13.50r22 on 14 wide rims with a -76 offset on a 6" lift and 1.5" body lift
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Wheel is 20x10-25 tire 33x13.5x20 running 2.5 leveling kit
Kind of depends on the factory height some Rams can get away with clearing. Are you going for the Stuffed look or is budget getting in the way of what you would like to do?
H
Hannahemi17
Plymouth meeting, pa
On a budget. It’s 39in the rear 36.5 in the front. I ordered the tires and wheels be4 I thought it through. I have my fingers crossed that leveling it I won’t have todo to much plastic trimming at worse
