just installed lockpick w/ camera
Rumblebee#2331
Rumblebee#2331
Vernon,Ct
I followed the brake lines up the drivers side and through the rummer grommet in the fire wall for the parking brake and then into the dash
Jluge2615
I already have rear camera but i would like to add the front camera. How would the front camera work? Where in head unit would u go to click snd see tge front cam?
Halln
easiest install took longer to run cable for the camera then anything and works great! any questions post up!
I have the lockpic and I'm being told I can't do the install. I have a 2011 Ram with the mygig radio. Does your truck have the same system and where can I find install instructions or video for this job?
quietpeen
2021 TRX
Hellcat
Welcome to rf. Who is telling you that you can't do the install
Rumblebee#2331
Rumblebee#2331
Vernon,Ct
i have the lockpic and i'm being told i can't do the install. I have a 2011 ram with the mygig radio. Does your truck have the same system and where can i find install instructions or video for this job?
somebody is lieing to you!
Halln
I recently purchased the lockpick. I have a 2011 Ram and I dont want to screw up my interior with the install. Can you provide the steps you used or links so I can see how the process. thank you in advance.
quietpeen
2021 TRX
Hellcat
check out this thread. It should give you the info you need on taking the dash apart. BTW this is in our 4th gen DIY section. Check that section out....lots of nice how to threads.
http://www.ramforum.com/f75/diy-radio-removal-integrate-after-market-amp-11201/
CLOTAGAMES
illinois
My video cable was about 2 feet short-power cable was ok-had to get a short RCA video cable and adaptor to reach.
noraa73
