K&N Air Filter Help?
99RamSport360
5.9L Magnum 360
I was wondering if the K&N drop in air filter will make the truck louder and perform better then just the stock filter. It will go into the stock filter housing for now before a CAI. Any thoughts and experience is appreciated.
moparman
Woonsocket, RI
2016 Ram 2500
Re: K&N Air Filter Help?
I didnt notice anything at all to be honest. The main reason i bought mine was the benefit of hosing it off, putting some oil on it and sticking it back in the box. Some peoples butt dynos read 100hp gains and others say they saw nothing. If you can justify the money to buy it, go for it
Sent from my Galaxy S3 using Tapatalk 2
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Like said, they are only good for the fact that they will last the life of the truck. You wont feel any performance increase with it though unless your current filter is extremely dirtys and choking airflow.
brightwhitesport
In my Dakota,I used to see a noticeable improvement in fuel mileage after I cleaned my k&n I usually got about an extra 50km to a tank.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
A clean filter will always run better, but the difference in performance between a clean paper filter and a clean K&N filter is marginal.
99RamSport360
99RamSport360
5.9L Magnum 360
Thanks guys, but will it change the sound at all?
Psycho White
Alberta
actually if you have the A/C and radio off, at higher rpms i can hear it sucking in air
WhiteExpress
Midland, TX
do some research into the filtering qualities of oiled gauze filters vs paper before you purchase one. I wasn't impressed with what I read.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
A complete cold air intake will give a noticable increase in intake noise, but a filter swap lone in the stock airbox wont give any extra noise.
brightwhitesport
I'm sure my experience would have been the same replacing a dirty paper filter with a new filter, reuse able filters are just really convenient
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I went with the dry flow from AFE I got sick of the clean and oil practice as I always did it in the bathtub and the oil stuck to it for days and it was red so easy to see. I am not a fan of cotton gauze filters that need to be oiled. To do it again though I would go with the nano fiber Amsoil filter it is only rated for 100000 miles but that filter will out filter all these other options.
$miley
glsander
