Keep overall tire size the same with 17" wheels
ncaabbref
Midland Texas
2013 Ram Longhorn All Options
Hemi 5.7 w/ 8 sp Auto
Hey guys,
I am anxiously awaiting delivery of my 2013 Longhorn with air ride suspension, and I need to change wheels/tires on it right away for my job.
What tire size do you recommend to prevent rubbing when the suspension in full park mode?
Thanks guys,
Jeremy
quietpeen
2021 TRX
Hellcat
what do you mean you need to change the wheels and tires for your job.
from the title i assume you are getting 20's with the truck and want to switch to 17's. The stock tires on 20's are 33" tall so to get a 17" wheel with a tire close to that would be 285/70/17. Would only be a little bit wider but shouldn't rub at all as long a you don't get wheels with more backspacking than the stock wheels
ncaabbref
ncaabbref
Midland Texas
I work oilfield sales and I need to switch to a 10 ply tire due to hazards in the field.
ncaabbref
ncaabbref
Midland Texas
So if I wanted to push the envelope and go a little taller, what would be my max tire height?
WhiteExpress
Midland, TX
285/75R17 would bump you up in height yet keep a respectable width.
Not sure they made that in a 10 ply.
Too bad you're so far away, I'd sell ya my stock 245/70R17 10 plys.
They are too damned small for my taste.
ncaabbref
ncaabbref
Midland Texas
Thanks for the reply, white!
What common size could I get in an on/off road tire then?
WhiteExpress
Midland, TX
285/70R17 is a very common size.
It will fit nicely w/ only the possibility of minimal rubbing.
ncaabbref
ncaabbref
Midland Texas
What is the stock offset?
ameer73
