Key FOB Rubber
ddttm
Doylestown, Ohio
Does anyone know where I can get just the key fob rubber piece for my 2016 1500 big horn? One of the metal disks on the under side of the button fell off and I can't find it to put back on.
EdGs
FL
Amazon.com
Buy the same type, with same functions, and swap the rubber with contact discs to yours.
EagleChief
Oklahoma
2014 Big Horn
Yep. Amazon is your friend. They are pretty cheap, too, if I remember correctly.
Do you have the Passive FOB, the type that you insert in the ignition ?
Carandtruckremotes used to have the Passive FOBs in stock
but right now they only have the enterandGo shells
EdGs
FL
I couldn’t find just the rubber on Amazon or eBay or rockauto.
You won't. Buy the case with rubber, open it, and use the rubber with contacts in your fob.
Simple, and relatively cheap.
southalum
