Key Fob
Mikedc1144
St Peters, Mo 73376
2021 Ram Big Horn: On trip neither key fob would open doors. Used key to get in.
Once in, started truck-all normal!!
No problem since!!
Any ideas???
turkeybird56
Central Texas
RF problems? Unit not working, synched with FOB>? Hmmmmmm.
IF all OK now, taking to Dealer U will get the ole: Cannot duplicate. Hopefully, just a glitch and/or maybe some type of interference blocked FOB.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I have no advice, just a bit of information
If you Ram has the Keyless entry, Enter and Go
Not only does it have the ignition switch, it also has an RF HUB behind the rear seat on the drivers side
MADDOG
Living in a Firepit
6.4L HEMI
Sounds like batteries. Let the dealer sort it out under your warranty.
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
Did you recently replace any bulbs with LED's? That can cause issues like this.
GTyankee
3.0 ecodiesel
Because of LED lights at a 7/11
My doors would not unlock
On my instrument cluster, i saw a message read out
I could not read it, but it was likely something like
FOB not recognized
after that, i always parked further away from the front door of the building
brian42
San Diego, CA
2019 5th Gen (Sold)
HEMI 5.7L
Lots of stuff nowadays that will interfere with the signal, including having your cell phone near your fob.
gville35
