Keyed Power Source Under The Hood
reloaderguy
Oregon
2016 Power Wagon
Can anyone give me a keyed power source under the hood? It would be great if there were an empty slot in the factory fuse box but that is probably too much to hope for. I need to power a relay and don't want power running when the engine is off. The truck is a 2016 Ram 2500 Power Wagon.
Fenrir14
Houston, Texas
I can't believe no one replied to this. Did you ever have an luck with this? I need the same thing lol
Sent from my LM-V405 using Tapatalk
ljmasonwy
6.7 Cummins Turbo Diesel
Somewhere in the forums is a link to the UpFitter Schematics... in them (year/model specific) it tells you which switched fuses can be used and the allowable amperage
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
I added a tap-a-fuse to #92 for my aux project. it had a fuse, not a blank, wired fuse though.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
When I got my 2018 below is what I found and tapped in under the fused distribution panel. Not sure if it carries over to other years.
noraa73
