Knocking in my front
Dieselpower87
5.7 hemie
Knocking in my front end
Hey guys I got a 2007 dodge ram 1500 with 5.7 hemi I have a loud knocking in the front end when I take bends and hit dips in the road so I thought CV joint so I got home went under the truck checked that got a little bit of play in both sides but nothing to loose any sleep over so I jacked the truck up checked upper and lower ball joints on both sides and tie rod ends everything was all tight there so then I checked universal joints all good there so I checked that little universal joint on the steering shaft under the hood and everything is tight there what could be causing the load knocking in the front end? Please help I'm at a lose. PS it's definitely not motor related it's something with the front end or front suspension. Thanks in advance
ramportin1
Sickest member here
Oregon
Hmmm, are you positive not CV joint? Other then that and what you've already checked I would say check your sway bar bushings, I had one deteriorate on my 07 and caused quite a bit of ruckus. Front ends on these bad boys are finicky to say the least
Immortaldaul
San antonio tx
5.9 magnum
Maybe it's the rack n pinion I know my 02 needs em replaced and there's play in the tires because of it
Sent from my Moto G (4) using Tapatalk
reindeerman
Knoxville, TN
2011 & 2002
I had something similar in my past 3rd generation. It was the sway bar links. I used a needle fitting on my grease gun and shot some grease in through the boots. Noise went away.
