CantRepeat
- Apr 23, 2019
- 125
- 150
- Location
- 127.0.0.1
- 2010 2500 Crew Cab
- 6.7L Cummins stock
Anyone ever experience a leak coming into the cab from the 3rd brake light?
Damn, didn't know it was that common of an issue.
Hopefully I can get it out without moving the shell back.
Thanks.
Nice little gap in the seal around the satellite antenna near the passenger rear on the roof. Use a plastic trim tool to lift the antenna up a bit and get some silicone under and around it. So far no leaks!!
You mention the passenger rear. What year is your truck? Because I only have a shark fin antennae on the drivers side rear...
But I did go to car wash and blowing water everywhere realized I somehow wedged water inside the back window. Assuming between the sliding glass. I sealed he 3rd break light so I don’t believe that would have caused some water to come in..
It's a 2010 crew cab. It has a square antenna over the right rear passenger area.
Is it, by chance, a Canadian truck? Those got the squares instead of the shark fins, as Sprint services for our trucks was not offered in Canada, so they didn't get the special cell antenna.
When I did my 3rd brake light (preventative, before I had any leaks) with the newer/improved 3rd brake light (later part revision), I sealed around the antenna as well with weatherstrip caulk/glue. No issues yet.
Grrr, just went and checked the truck and I still have a leak some where. The passenger rear headliner, window and seat head rest are wet and there is standing water on the rear window.
I think Mopar came out with a new improved third brake light with a better gasket, The new 5 Gen trucks have 3 screws holding the light in place but 4 Gen don't. My advice is to buy a whole light set up including the light itself. My friend just had the problem and got a new third break light. They should really have a recall on this common problem. Also if getting new 3rd light you can install led bulbs ,because you don't want to close it up and open it again. He paid 68 bucks from Mopar for the light .Anyone ever experience a leak coming into the cab from the 3rd brake light?
