Leaking fluid can anyone help??
Fc3s25
California
Just started happening smells like coolant.. really don't know.. just a point in a right direction.. thank you in advance
BLUEDERANGO
Law Enforcement
392 Hemi
Lately it seems the water pumps are the culprits,, depending upon the dealer you use it may be covered under warranty.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Disconnect the Negative Post on the Battery
Then reach the underside of the water pump, right below the shaft you may feel a hole.
If the hole is wet, the water pump bearings are going bad
Fc3s25
Fc3s25
California
i didnt see any of these responses until now.. but wow i'm very grateful for the advice and response and yes you guys were all right it was the waterpump after doing alot of digging from all the great ppl on this forum made it easy for me to know and how to do it all.. I APPRECIATE ALL OF YOU.. 200.gifhope everyone is well.. stay safe..
