Leaking K&N oil filter
seabrook
seabrook
Black 2018 Night
5.7 3.92 anti slip
beware- first oil change used a K&N and found it loose on next oil change I had already bought another K&N filter so I put it on and saw oil spots on my driveway 1000 miles after the change. So I slid up and the filter was tight but leaking oil wtf, pulled it off and put on a Mobil 1 113a.
Ramnewbie
I also had a leaking K&N oil filter. Mine wasn't pulling up square against mounting flange, bad part was that it didn't leak in the driveway, would only leak when going down the road. That was the last K&N for me.
Sent from my XT1650 using Tapatalk
seabrook
seabrook
seabrook
Black 2018 Night
5.7 3.92 anti slip
Yep I think mine Wasn’t square either- last one for me too
huntergreen
Marine Corps Navy Badge
The quality of K&N has taken a nose dive. I did like the nut on the end though. I suggest using a synthetic filter, either royal purple or the fram ultra. Both are synthetic with excellent specs.
seabrook
seabrook
seabrook
Black 2018 Night
5.7 3.92 anti slip
Ok man thanks I’ll try those next. Is the m1 filter not good (it’s m1 xcare 113A) yea I really liked the nut too, great idea by k&n
huntergreen
Lol. The nut on the end wasnt K&N idea. I remember Hasting filters had the nut back in the early 60s my father used them.
I am not sure if the M1 filter uses a fully synthetic media. The RP filter is most likely the best. I use fram as it is cheaper ndveasily obtained at Walmart. My oci is 6000 miles or six months, so more than up to the job. Most likely more than I need. There is an oil filter thread started by burla you may want check out. There is also a synthetic oil thread with great info, but it is quite long. Feel free to do some reading and jump in with questions. Good group of knowledgeable guys in there.
Buddy
Ottawa, Ontario - cool town
Oh wow, been using K&N on my Trans Am for a decade, never had a problem once. Will pay more attention now.... might switch to RP. K&N is just easier to get.
Ratket
Arizona-
Royal purple filters are excellent.
Funny story- 1 company makes like 90% of all oil filters, they just make them to the manufactures spec.
swexlin
West Chester, PA
Well, may not be the filter. Search my back posts, my Mopar filters have backed of and leaked 3 times now. Always dealer oil changes and they state there is NO damage to the housing. They can't figure a cause. So just sayin'....it could be a situation similar to mine. Usually starts about 1000-1500 miles after an oil change.
Ramnewbie
Some k&n's are made in Mexico, some in the USA. The one that I had leak was made in Mexico, since then same part number is made in USA. They have also changed their base plate from having a whole lot of inlet holes to 6 inlet holes.
turkeybird56
Central Texas
Next time U do an oil change, look at the spindle and check for thread damage. There have been reports of damage done to threads etc by over tightening of initial filter from factory.....
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
The RP filter is excellent, I use it on my 16. I run the SRT filter on my 11. It performs very well and easily goes for 7500 OCI with redline 5/30.
This is with 105k on the clock.
Noeyes
Kentucky
Had the same thing happen to me. I've always liked and used wix filters so I had one installed on the first oil change. I had an oil shop do it because of what I read about the filter being welded on from the factory. Lol. That being said I can't say how tight they installed the wix but after about 2000 miles I went out to the garage one morning to find a large puddle of oil under the passenger side front and thought something catastrophic had happened. Come to find out the filter was loose and leaking. No big deal I suppose but hope it doesn't become a repetitive issue.
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
If you look at how the seal ring is installed on a K&N, it is easy to see why they tend to leak. last one I had you could easily remove the ring from the seat. RP, Amsoil, Fram Ultra are all full synthetic mediums with high particulate ratings and well made.
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
I've used K&N's on everything I own that has a motor with a filter (car/truck/jetski/boat) and never had a problem. Not sure if this has anything to do with it, but the nut is ONLY for removal and not to be used for installing it as it can cause the filter to deform.
