Lean Rear Seats Forward
Ram_d00d
California
I have a 2019 1500 Classic. Big Horn quad cab. In the back my seats have been raised 3/4 of an inch and the seats won't lean forward like they did in my Laramie. How much do I need to cut off the hook in the back to make this work. I need the space
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
The best answer is "as little as possible". You may want to try just removing the nylon glides to see if that gives you the clearance you need.
duckman631
New Jersey
2016 Big Horn Crew Cab
Hemi 5.7 K&N Cold Air Intake.
I had to hacksaw about a 1/4 inch off the metal hook even with the 3/4 spacers
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Not sure which year or quad or crew cab this video is about
https://www.youtube.com/watch?v=JEHWA4-1tIo with bonus mod
Gen 3 seats, i think they just flipped the fasteners on the cabs rear wall upside down ??
Ram_d00d
Ram_d00d
California
Thanks for the replies. I didn't think it was much that had to be cut
bm02tj
B C Canada
I feel it is best to cut at bottom of nylon and not add the spacer under seat
Ram_d00d
Ram_d00d
California
I had to raise the seat to fit the Fox Box under it
