LED high beams dont fit
Tink1704
Vancouver WA
Everything I see says the high beams for my 2017 Ram 2500 is 9005/HB3. When I went to install they don't fit. The connection is the same size as my low beams but with smaller diameter inserts. Anyone deal with this?
Johnny_B-Good
Pennsylvania
I believe (which means I could be wrong). If you have projector housings, the high and low are the same. 9005. If you don't have projector housings, the low beam is H11. And fog lamps are 9006. Hope this helps...
