Led light cubes
jknappen
Kentucky
what would be the best way to mount a couple of led light cubes under the back of a 1500? Would rather not drill into the bumper.
Steveo8x8
So Cal
2017 Ram 2500 Megacab
6.7l Cummins
Use the existing bolts already there and just slide a bracket under one of them
mtnrider
Georgia
^ Seems like that bracket would prevent you from using your safety chain hook ups?
Steveo8x8
So Cal
6.7l Cummins
Nothing wrong with that bracket. I just preferred to have them tucked up slightly underneath and a little more hidden88cef610f379bc04cec5e7c06e57e61f.jpg
ramrocker
Pearland, TX
6.7L CTD
This is on 3500. Don't know if bumper mount is the same or not.
Added couple of L brackets under the bolts there.
MarshRam
2014 SLT 4x4, 2012 ST
Mounted mine to the hitch with exhaust clamps.
Dinky
Oregon
I know you don't wanna cut holes. This is the best way I think looks really clean and don't hang down into space. Also I wired to my reverse wire on my trailer plug so they come on when I shift into reverse
Dinky
Oregon
Best way to cut the chrome bumper?
I had pictures at one time. I used blue masking tape. Taped off more area then I needed. Use a piece of cardboard as a template (of the size of hole and shape). Put cardboard on bumper. Make sure you look behind and double check for clearance. trace cardboard then drill hole in all corners of your pattern. I used a jig saw with a metal blade and connect the dots. Take a file and deburr if needed and spray some paint on cut edge.
This is with wood but some principal
jknappen
jknappen
Kentucky
I like that. Those are the lights i have. How are they mounted?
Steveo8x8
So Cal
6.7l Cummins
Just used an “L” bracket from Home Depot and widened the hole so I could use an existing bolt. I’ll try and take a pic for u on my way to work
Jantelaw
