Led light
warlock23
Canada
v6 pentastar
I have a 2923 Ram Classic Warlock V6 4 doors with Projector Headlights. Does anybody could recommand led lights for the High and low beams , that don't flicker and are reconized on my truck's computer's module.
Thank you
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Thank you
Do you have AlfaOBD?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
No I don't
Ok, I was gonna say if you had that your options are pretty unlimited. I've never needed the compatibility modules because you can tell the BCM what is present. If you are going to spend more than $50 to make it compatible, just invest in AlfaOBD, it can do a whole lot more....
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
I have not seen a 2923 Warlock yet so must be cool to be the first to test one lol
Glad to see I am not the only one that types in 29** :O
I have Quads on my SEL 2015 and OEM bulbs.. Game plan is this spring/Summer so all theses LED threads are real helpful
Thank You
CanuckRam1313
Ontario Canada
2023 Warlock
Thank you
You want these ones here for both the highs and lows.
I have them in my 23' Warlock with projectors and they are plug and play and work great!
Make sure you clock them properly and ensure they are aimed correctly, too, so you don't blind anyone.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
CanuckRam1313
Ontario Canada
2023 Warlock
That design looks pretty legit. I'll add these to my cart for when I need new highs...
They are excellent bulbs and have a great warranty, too.
In the projectors for highs & lows they really cast out the light well.
I had the Fahren's in my 19' quads, too.
Zero modifications for the housing covers as well.
Pure plug & play with no hassles or dash warning lights.
RamDiver
Marlborough, Ontario Canada
2021 DS
How do I clock and aim them, do I need to go to Dealer?
They include instructions and a tiny allen wrench to losen the set screws on the rotating collar. The ideal position is clocked to 9 & 3.
On several Fahren LED bulbs I've clocked, 9 & 3 end up the wire connection at 12 or 6.
On the Projector housings, you can only see the bulb orientation on the high beams. The low beams are hidden by the projector lens.
This is my favourite headlight alignment vid.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
I just put these in my truck's projectors 2 weeks ago when one of the bulbs lost one side. Very easy to get clocked correctly.
Very defined line on the low beam lens from 12 to 6 o'clock when looking directly at the low beam projector when on, but not visible in the projected beam. They do provide a super crisp cutoff line from 3 to 9:00 o'clock when against a wall.
