Led question
blackout11
alpharetts GA
2011 R/T
Ok got them in my turm signal my brake/parking/tail /turn signal work great but why the F do they flash so quick when i use turn signal.
BigH0ss
Banned
Get a relay in there! Or change out the flasher.
blackout11
blackout11
alpharetts GA
2011 R/T
Umm should not have to do either they are 3157 led bulbs should work they are plug and play
Stangshcky12
Oshkosh, WI
5.9 Cummins
You need a resistor. Even though They just plug in the LEDs pull so little current that the trucks computer thinks the bulb is almost burn out. It's supposed to be a warning that your lights going to burn out soon
blackout11
blackout11
alpharetts GA
2011 R/T
Would i need 4 or 2 or what lol more money and more waiting sigh.And how are they spliced in i see 1 wire and my signal bulbs have 2 would i need 4 1 for each bulb or what never hooked them up not sure how they work.
blackout11
blackout11
alpharetts GA
2011 R/T
Computer controlled lights...........no "flasher".
Just splice those in, they work great!
Ya just popped the hood lol found that out ahh not badd at 5 bucks each halos will be in monday should have the lights done soon
blackout11
blackout11
alpharetts GA
2011 R/T
Ok which ones do i need
6 Ohm, 50 Watt resistors can be connected across the turn signal bulbs to simulate the load of a regular filament bulb (2 Amp load). Leads are 12 inches long.
25 Ohm, 25 Watt resistors can be connected across marker lamps to simulate the load of a regular filament bulb. Leads are 12 inches lon
blackout11
blackout11
alpharetts GA
2011 R/T
click those links they are 5 bucks apeice but there are 2 different ones dont know which one i need they have different ohms
2010 Dodge Ram-pickup With-4-headlamp-system LEDs
to the right it says flashers and resistors they are on the bottom on that page just not sure which i need cause both have different ohms and watts
blackout11
blackout11
alpharetts GA
2011 R/T
Do i need 2 or 4 i have the leds in my front turn signals and rear brake/turn signals
quietpeen
2021 TRX
Hellcat
what did you decide to get?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
50w6ohm
you need them on any that act as a turn signal and parking bulb.
tobyjohnson11
I am thinking about putting leds in all my exterior lights too. So what exactly did you get?
electricalservice
