Led reverse light bulbs ?'s
lilzilla2008
Can I just replace them with normal led bulbs or do they need a certain resistor or anything? Also what is the bulb number for them for a 2014 ram? Thanks!
kris319
Miami, FL
7443 is the number. Canbus bulbs don't work, you'll need resistors if you want to get rid of the error message.
Sent from my SAMSUNG-SM-G900A using Tapatalk
L
lilzilla2008
So no one makes a bulb with a resistor in it? I'd figure the oem bulb would need one unless it's just for led bulbs
BlownGP
Houston/Baton Rouge
You shouldn't need a resistor for the reverse light
RyanJM
Houston
2014 Express RC Black Edition
I have normal led no CanBus in my 13 and 14 no error lights at all.
mjd91
San Marcos, TX
Error light in my 13 Sport.
I even bought the high end RetroSolutions CREE bulbs.
The error comes and goes. Comes on for sure if I leave the reverse lights on for a little bit.
firemedic10584
Central Fl
I bought some LED bulbs from an Ebay member that was recommended from another member on another forum. They're real bright and I did not get any error messages on my '13 sport either. But every truck is different I suppose.
VTBighorn
'14
I get an error when I shift into reverse, it stays there for 5 seconds and goes away.
as for reverse light bulbs it depends on your truck.
some run 921's others run 7440/7443
I have a non projector headlight truck it takes 921's BUT I swapped TYC LED tails in (sport model look LED) those run 7440/7443's
go to superbrightleds.com theres a whole search available for specific vehicles.
VTBighorn
'14
I decided to throw the LED 921's into the 3rd brake light area as the new cargo light, HUGE IMPROVEMENT
even with the flash on
joshhhh
