LED Reverse lights and tag lights. Error?
I was looking at replacing all my white halogens in the rear of the truck with white LED bulbs. My question is do I have to do anything special to run them or are they plug and Play? I'm referring to any lamp out lights or flickering. Truck is a 2014.
Thanks
Heywood
Alberta Can.
2010 Sport
Don't know about issues with flickering, but I have heard of some concerns with brighter LED plate lamps washing out the back up camera's at night?
Mark182005
Qc
I have the LED plate lamps and yes they do cause some glare on the screen but you can still see pretty clearly when the freakin camera lense is not dirty.
The only issue is the lamp out message when you start the truck.
X Gixxer 1000 X
I don't have a back up camera unfortunately. I can't see much backing up so I was looking to replace the reverse lights and my OCD kicked in and I need everything to match back there.. So yea, fml. Lol
BlownGP
Houston/Baton Rouge
There all plug are play but like mentioned it seems the 2013+ only have the lamp out message.
JohnD72
Charleston, SC
If you do a search on the forum, there are multiple threads on which LED's you need for this, as well as the resistors required to stop the lamp-out warnings.
JohnD72
Charleston, SC
I thought this was an interactive forum, not a database.
This is certainly an interactive forum. If you're unhappy with the form in which that interaction takes place, that is most unfortunate for you.
In addition, the fact that the information that is shared is archived, indexed and readily available would suggest that it is, indeed, also a database.
Good luck in your search.
JW597
I am completely new to this LED world and have been trying to figure out where and how to solder the resistors onto the LED bulb. I just installed both cargo/3rd brake and license plate lights. I now get a license plate light out and rear brake light out error. I know I need to solder resistors but I have no idea where and how. Or what the end result should look like. And I have been searching for days now with no success. Any ideas?
X Gixxer 1000 X
This is what I'm trying to avoid. Lol. I believe the resistor goes in line with the LED. Maybe solder is to the actual metal prong? I hate electrical. Plug and play is good. Lol
ddavis
Bethalto, IL
Since no one has given a straight answer, no, there is nothing special needed to change the reverse and tag lights, just plug and play
Sent from my SAMSUNG-SGH-I747 using Tapatalk
X Gixxer 1000 X
I think the 13-14s are finicky. Everything apparently is canbus based. I have some 194 LED bulbs laying around from my old ram I'm going to swap and see what happens. I was going to order all of them in led but didn't want to get the wrong ones.
SafetyMan43
San Antonio
...the fact that the information that is shared is archived, indexed and readily available would suggest that it is, indeed, also a database.
Then how hard would it be to share a link with the guy looking for information?
Just sayin'
:happy160:
mcompany
Canton, OH
2011 Power Wagon
Resistors are easy to splice in man. I did it on my switchback turns tail lights reverse lights third brake and license plate lights. So I would have no trouble with these. Although my 2011 didnt need it. I did it anyway. They take all of 5 minutes to wire
Calvinmx48
Light a
I just replaced my LEDs that showed a warning to canbus LEDs and the message went away
Bought them on eBay sorry can't remember from who
JohnD72
Charleston, SC
Just sayin'
:happy160:
No harder than it would be for someone to use the search feature and find it themselves.
Just sayin'.
:baby:
The resistors are spliced into the positive and negative wires in the bulb harness, thus creating a load and preventing bulb-out errors.
Heywood
Alberta Can.
2010 Sport
Not sure if it's the same, but my switch back LED signals used a tap to the hot signal wire though the resistor and to the body/frame of the truck.
Put a load on the system so the ecm didn't mistake it being out due to such little load.
JohnD72
Charleston, SC
Resistors will generally come with instructions but they will always connect to the hot wire and a ground of some sort.
You're basically shorting the hot wire to ground to create additional load; the resistor simply keeps the amperage low enough that it doesn't overload the circuit.
stevo5441
