LED Turn Signal out Message
BK_Viruz
Hello I installed after market LED projectors on my 2014 sport and the lights work fine but I can’t get rid of the messages saying “bulb out”. I have tried using my Alpha OBD to change the system to “LED turn signal enabled” but it still keeps the messages. Any help would be appreciated thank you!
B
BK_Viruz
I cleared the codes and they came back so I unplugged the battery to reset completely and they came back after a few seconds of use so I guess they are not compatible. If possible do you know of any trustworthy resistors I can look up? Thank you.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Here you go
NJMOPAR
Older and faster
ELizabeth, NJ
Those bronze Chinese resistors get VERY hot and will melt wires or plastic.
Usually will burn out within a few months.
They make CANBUS-safe LED signal bulbs, Syneticusa worked in my 2010 but they have external resistors built into the wire. Newer bulbs are self-contained.
