hemi1300
- Sep 22, 2011
- 386
- 3
- Location
- Columbus, Ohio
- 2007
- hemi 5.7
as i anxiously await my retrofit projector lights from jj, there is one thing i noticed that will probably bug me. After looking at a few pics on his site, u can barely even notice the amber turn signal lit with the housing being painted black, guess the chrome helps reflect the light on the stock housing. Was checkin out some led bulbs for the turn signals, here are the one's i'm thinkin abouthttp://www.v-leds.com/Exterior-LED-Bulbs/Turn-Signal-LED/Amber-LED/V-LEDS-AMBER-75W-HIGH-p9593082.html
these should make them nice and bright i hope? Question is about the flash rate, i'm sure it will have a fast blink on the signals bc of the resistance and the truck will assume a bulb is out. Do they make electronic flashers i could just swap out, or would resistors need to be wired in. Would much rather purchase an electronic flasher instead of splicing into the stock wiring, again!!
Also might pick up one of thesehttp://www.v-leds.com/Exterior-LED-Bulbs/License-Plate-LED/White-LED/V-LEDS-HIGH-POWER-18W-p7516915.html
bc the backup led's on my recon smoke lenses suck ass. Saw some pics of a member with one of these installed, and WOW that sucker is bright!!
