Level kit with new rims and tires OR Tuner and intake??
UnsatFC
Active duty NAVY
New Jersey
I have a choice to make. I can either get a level kit with some new rims and tires OR I can get a tuner and an intake. I would like to get everything at once and that was my original plan however I don't want to wait anymore. I need advice!!
jenham
Tuner voids warranty level and rims don't. If not on warranty up to you if you'd use the off-road capabilities or just extra power
UnsatFC
UnsatFC
Active duty NAVY
New Jersey
Since I have a 2015 I would have to get a unlocked PCM with the tuner. IF anything went wrong I would have the original PCM to put back into the truck. Unless I am mistaken isn't that how people are getting by with warranty work?
Devin1349
@UNSATFC dealerships can see if a tune was put in a truck even if you restore the original pcm i believe i read it somewhere here.
OP get the level and tires in my opinion
Devin1349
@UNSATFC- Did you make rank this cycle???
Jeffnc84
Apex N.C.
2015 ram
Look as to what I'm going to be doing
Sent from my SM-N910V using Tapatalk
TonyMM
2016 RAM 1500 CC 6"4 4X4
WithaA tuner/ intake you will have a new truck! And no MDS! Really nice!
New rims/ tires will also change your truck at least from outside.
I will personally go for the tuner. Alone because of the MDS off!
UnsatFC
UnsatFC
Active duty NAVY
New Jersey
I'll have to see about this...I though I would be good with the PCM swap. I'm already out of my bumper to bumper warranty and I have the 5 year 100k powertrain. I'm sitting at 37k right now and 3 more years. I would hate to have something break and no be covered.
BiGMERF
2017 SLT 4x4
v6
Rims bruh. Dewit
Rzrman328
The treeline
Lift n wheels brother.
I couldn't care less if my ram is fast.
BiGMERF
2017 SLT 4x4
v6
I could careless if my ram is fast.
Same feelings here. Going fast was last on my list of needs when shopping for a truck.
TonyMM
Tuner is not about going fast. You can have it for that.
But for me it is more about having a real V8 and not the MDS V4 in my truck (except the OP has a diesel).
UnsatFC
UnsatFC
Active duty NAVY
New Jersey
Leaning more towards the rims/tires since they are on sale. I'm thinking about not going with the TPMS but dealing with the light on the dash I'm sure will get annoying.
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
Thought i read that manually putting it in 8th gear instead of drive will prevent mds. Is this correct? And does putting it in tow mode do the same?
UnsatFC
UnsatFC
Active duty NAVY
New Jersey
I tried this today and it worked. I have the 6 speed and a column shifter not the knob. Hit the minus button to put it in manual mode. Then hit the + button until it was in 6. Continued to drive, stop, accelerate. The truck went threw the gears and no MDS light came on.
TonyMM
Manually yes!
Tow mode no.
ECO light is not MDS.
atc06jh
Middle Georgia
I wanted a tuner and all the stuff too. But I decided wheels and tires. Don't void the warranty and are you "really" going to use the HP and such from the tuner? Polly not.
Ram Night
Southwest, Michigan
I would not waist my money on a CAI, because most of them will only make more noise, and no power. I would look at a tuner if you do not care about the warranty, go with t a tuner. But new wheels and tires will look good also.
