Level on 35s? also rear spacers?
brandonbomer
Anybody have pics of 35s with a 2.5 level on a 2wd. I like the rear squat look but I may run a 1 inch rear just to have full level. Just wondering if y'all had pics or what y'all ran
012RAMbo
West Monroe, La
Don't have any pics, but the rear won't squat with 2.5" level. If you add 1" out back it will give you some rake back.
SuperTrooper
Douglas, GA
If you run bilsteins at 2.8 you MAY get a very slight squat. If you want any noticeable amount you would probably have to put a 4" lift on the front only, with maybe a 1" or so on the rear.
Rams' factory rake is one of their only downfalls, IMO.
h2oman
SoCal
I have a '12 at 2.8 and still have one inch of rake.
B
brandonbomer
Thanks guys I was hopeing for alittle squat but level is fine to
RAMYOU
Do you think BDS 5.5 lift in the front and 2.5 in the rear will look awkwardly sqwatted for a 2500 or do you think it will look almost level?
SuperTrooper
Douglas, GA
Measure the front and rear fender heights, then add the lift to them and see how even they come out.
I don't think squatted looks bad. I like a squatted truck as long as its not too overdone. I'm probably going to move from a 2.5" to a 3" level when I get my 35's and Ranch Hand. It'll put my nose about .5" higher if the weight of the Ranch Hand doesn't drop it down.
RAMYOU
I hear people say that ranch hand full bumper pulls the front down by half an inch but it will depend on the type of suspension u have. Also, did you buy your truck new or used? Have you always had 3 inches of rake or has it been increasing since you bought it?
SuperTrooper
Douglas, GA
My 2.5 spacers had it completely leveled when installed on my new truck (2014 1500 CCSB), but my front suspension has settled a little so they're about 1/4 inch lower. Hence why I want to go with a 3" spacer when I install my ranch hand.
