Leveled Ram 1500 4x4 with 35x12.5 fit!
Mbrigh3
IG: Stormtrooper_5.7
MD
Hey guys, l pulled the trigger on 35x12.5 Falkens my Ram 1500 and they fit. They were the stock size in falkens. The 35s only rub when I turn left at %100. Beside that flawless. I'll show before and after belowcc417851f5114fdb7ae455ba86463107.jpg8efbacb02abf92e10fbdd89da587d74c.jpg82c7d564c0c1f0052a772ef3b46eee88.jpgd2c387f03b125a26df51d5864709a8d3.jpg
Mbrigh3
Mbrigh3
MD
I thought a bunch of us had a leveled ram with 35's? hm
Jomikesimpson
Missouri
Hey guys, I am about to pull the trigger on 35x12.5 Falkens my Ram 1500 with a 2.1 front level on a sport 20" Wheel. I currently have 275/60/20's A/T Falken tires on the stock set up. Should I stick with that or go bigger with a potential rub....
Post some pictures if you have a similar set up or opinion; Id love to see!
I don't have problems with rub2dbe1463e53e1de546450df175f2bc26.jpg3a21bf438e079e4164a172cc2adbd71b.jpg
Sent from my SM-G955F using Tapatalk
ram1500rsm
Trabuco Canyon, CA
This are Falken AT3W 315/70/17 with Rancho QL struts in the front, (2" lift) which are the same height size as Falken AT3W 35x12.5x20. My wheel specs are 17x9 -12 offset.
Falken AT3W Tire specs:
315/70/17 are 34.6" tall, 12.7" wide
35x12.5x20 are 34.6 tall, 12.5 wide
https://www.falkentire.com/tires/light-truck-suv-cuv-tires/wildpeaka/t3w-tire
45118463242_3fc6663882_k.jpg20181007_145507 by RAM RSM, on Flickr
You'll have to remove the rear fender liner if you're doing offroad
44396535341_8d0e92161b_k.jpgUntitled by RAM RSM, on Flickr
43712849874_88a81063e1_k.jpg20180902_105656 by RAM RSM, on Flickr
No front rubbing offroading, but i have aftermarket offset UCA's that allows my truck to run higher than stock caster 4.5-5*
44347151512_e613f74788_k.jpgUntitled by RAM RSM, on Flickr
44430788991_47827761c8_k.jpg20180902_105719 by RAM RSM, on Flickr
Mbrigh3
Mbrigh3
MD
Perfect! So I placed an order today. Ill have my Falkens on today by 5pm.
I got them down to 285 per tire for Falken Wildpeaks 35x12.5. I just couldnt pass it up.
Pretty excited
Jomikesimpson
Missouri
did you put on 35x12.5s? I have a heck of a deal on a pair and im abou to jump on it
Yes I did and I love the way it looks and performs on and off road.
Mbrigh3
Mbrigh3
MD
Tires are on! 0 rub turning left. Slight rub turning right at maximum. Love them! 7c3933f8fb8b4ee4bf0d3e89cc010912.jpg
Sent from my SM-G965U1 using Tapatalk
JoshR104
My old 1500 leveled with kings set at 2.1 with 35s.
JoshR104
See post above for pictures but offset will determine if you rub or not honestly. 35s with stock wheels will probably have slight rub at 2.1".
Mbrigh3
Mbrigh3
MD
There installed. I dont rub at all
Mbrigh3
Mbrigh3
MD
Good god that's close only thing that fits is paper! Lol 8e73aafac2e9f103a0798867c96ecfb4.jpg
