Leveling Kit
JoeS912
New Jersey
I have a 2017 1500 with a 5.7 Hemi and runs on 275/60r20 tires stock. I am installing a 2" leveling kit on the front. My questions is will I be able to run 275/65r20 (about 1" taller) without any potential rubbing? I plan to use the stock rims. Thoughts??
MADDOG
Living in a Firepit
Plug in the two tire sizes here to see what the dimensional differences are.
Tire Size Calculator
You can then measure your wheelwell opening and inside dimensions to get a better idea.
Another way is to contact a local tire shop about fitment.
crazykid1994
Yes. You’ll be fine with stock wheels and 275/65r20. If you go wider some people have issues rubbing the upper control arm and use 10mm hubcentric spacers to clear but you should be fine.
Badger 13
North Idaho
2013 Dodge Ram 1500
They will fit just fine. I have Goodyear Wrangler Duratracs in that size, LT275/65R20 with the stock wheels on my 2013 Sport. No issues.
Ckestly58
Hemet CA
2017 Ram 1500 AWD stock rims with 275 60 20 wildpeak. 3in RC M1 struts and RC UCA. About a half in gap between tire and UCA. Should this gap be larger?
