--Leveling the Rear to the front??
atrimpe1993
Hemingway 5.7
Alright I know I've been on here before bout the front spacer leveling and I'm not doing it anymore I'm going to save up for bilsteins but I was crying through eBay and saw a rear drop kit and level it that because I dont do much off reading and I like the somewhat low and aggressive stance. So my question is if I did a rear drop on my truck how low would I need to go for my coil springs and what else would I need to do or would just changing my spring be fine??
VB712
Maxi_built
Va Beach
2" drop springs in the rear and you're done.
SilverRam11
4.7 V8
With 2" drop springs do you still retain cargo and towing capability?
R.L.K.
Bristol , Tn.
Basically , just measure the center of the highest point of the Rear and the front wheel wells . At that point you'll know your rake. ..tipicaly 2.75 " to 3.25 " then simply do the math to achieve the rake or level you want .
Sent from my SM-G900V using Tapatalk
Fyredude
Edmonton
Do you need to change the planner bar? I think that's what it's callec
TRXHemi
Sugar Land, TX
Yep I did the McGaughy's 2" drop springs on my crew cab. It took me maybe 40 mins total in my driveway. Super easy, and it looks great.
A
atrimpe1993
Hemingway 5.7
Could you post pics
