lif question
reyescastillo1
New to the forum somehwhat but I recently ordered the rough country 3" suspension lift, install was pretty easy then mounted some 35s on it and I guess I was expecting a little more but not enough cash for the 6" at the moment so was wondering if I could add a rc 2" coil spacer and add it in ?
R
reyescastillo1
Pics of truck, everything shaved, 35s
usaf2006
North Carolina
I wouldn't stack lifts. Save up for the real deal. Looks good to me tho.
usaf2006
North Carolina
I mean sure anything can be done.. but it's not safe to stack lift spacers. They could break and your truck's front end would likely fall apart. And it'll most likely happen when you're doing 70 on the interstate, which would end badly for you.
You could get a 3" body lift instead.
Lil_Ram
Power tech 3.7L
Except for LS5 has been running it for some time I think he's running 7.5" lift from it
Lil_Ram
Power tech 3.7L
Seems sketchy to me
I don't believe he off-roads and RCX told him it wouldn't work. However it's the same principle as the isolator already there only larger.
R
reyescastillo1
I don't off road at all its a 2wd just for looks so I should be fine ?, I'd be good with my 3 and an extra 2" for 100 bucks , I wouldn't be stacking spacers I got the rough country suspension lift which includes new shocks and coil springs to get the 3" no spacer involved ? Just wondering if the stock a arms Wil fit ?, what is ls5 running ?
Lil_Ram
Power tech 3.7L
The 6" RCX kit with a 2in spacer I believe so he got the crossmembers which is needed for this set up
Csanders1992
No that will be way to much lift for stock suspension. Your bjs and tre would be at crazy angles.
Lil_Ram
Power tech 3.7L
Like he said no way to get your alignment right and suspension would be super screwed up u till you got the crossmembers
Lil_Ram
Power tech 3.7L
So cheapest way for looks would be body lift? 3"?
Yes but you won't really get the clearance off the frame like if you got the spindles. But that's your call.
Sorry no one ever got back to you. And I off-road in my my lifted 2wd often so just have to be more weary or what you go into
electricalservice
