Lift for 35's
Ferro
My Lord can we trade? I have a thing for your exact setup. I keep promising myself my next Ram won't come to my house unless its white, 4" lift, flares, sport hood and 35's haha
Looks a lot like my truck. How do you like the runningboards. I've been thinking about going with those for quite sometime.
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
I have a 4" superlift and 35s and am happy with it. I fit into my garage and into parking garages and no-touch carwashes with 7ft clearance. A 4" lift was a fairly far drop the first time I got out and didn't use the step bar.
M
mgdenver
How tall are you guys, total height with 6" + 37's? Definitely want to fit in my garage and in local parking garages.
I'm pretty set on the zone 6 + UCAs (thanks for all the advice)
Anything I should consider for my build? Sway bars or steering stabilizers?
Going to get a craven exhaust and try to get as much chrome off my truck as possible. Been stalking these forums about the best way to get black grills and bumpers plastic dip or vinyl wrapping. Damn Big horn has so much chrome. eBay seems to have all the badges and such in black so I'll be grabbing those.
Thinking about 35" Ko2s, since I'll be crushing a lot of pavement from Denver to the mountains and back (mostly hauling dirt bikes) and they preform pretty well all around. Had Toyo OC MTs on my last ride but I think they might be over kill for my use, as I'm just gonna be driving to and from trail heads on fire roads and i70.
JB1
Houston, Texas
If you want 20's check out the size 325/60R20, its taller/wider than the 35x12.50's. Not all tire mfg offer that size but BFG does.
M
mgdenver
Thanks, gonna get some aftermarket wheels so probably 18's.
Jwithing
STL
I think it's right around 6'11" clearance with the low profile antenna. The trimwork for the garage is 6'11" 5/8 and the 7ft garage door hangs slightly beneath that when open and the roof bumps the bottom of the door up slightly when pulling in. Low profile antenna. I've parked in the garage at work once because I had to... It states 7ft clearance and boy was my ******** puckered as I made my way to the top.
Also consider that's with current tread depth. Bought the vehicle w/ 30k miles already lifted w/37's, so not sure what the clearance is with new rubberand suspension lift that hasn't broken in.
M
mgdenver
Thanks, I'll measure my garage.
Now I'm thinking 36' tired might be the sweet spot. Hmmmm
JB1
Houston, Texas
only tire I know that's close to 36 for 18 wheel is toyo open country MT 315/70R18
jasper4230
Any of y'all see this on a four inche lift with 20x35
Sent from my Moto G (4) using Tapatalk
Ferro
Can't speak for others but I don't have that problem with a zone 4 inch lift with 35's.
M
mgdenver
Finally got my truck back from the shop. Thanks to everyone for all the advice. Ended up with Zone 6" lift with 35" Nitto Ridge Grapplers and Method NV wheels. What a huge difference the 6" lift makes, the wife is gonna need a bar / step for sure. No complaints about the ride, it rides like a lifted truck on 35's :happy107:
Next up:
Dechrome as much as possible, already got blacked out badges off amazon
Finish painting a 2nd grill and get a light bar installed behind it.
Install diode dynamics fog lights
Install Carven Exhaust.
Tint all around
Hopefully have that all done by EOM.
dan1911
Fairbanks, Alaska
Next up:
Tint all around
Looks great man! I got the same wheels and love them
And as far as dechroming, you could always bedline the bumpers and grille like I did! :happy107: It was a lot of work but totally worth it and get a ton of compliments
M
mgdenver
Seriously, im gonna get a quote to lineX front grill, front and rear bumper and hopefully play a few shops off eachother. If i can get it all done for a reasonable price i think ill go that way. White on black is my jam.
dan1911
Fairbanks, Alaska
http://www.ramforum.com/f75/bedline_your_chrome_bumpers-108370/
This is the DIY i made last week (i think?). Its not terribly difficult but scared the **** out of me to start it off. Turned out excellent. If you have a line-x place that'll do it cheap, go for it! There are no line-x in Alaska and I was hellbent to bedline the chrome
thekevin
Dang, why did you have to post pics of that. I have the same truck and I have been looking at lifts for the past week and this is not helping me save any money. What offset are you wheels and what gear ratio is your truck.
if anyone in Denver wants the chrome wheels and tires, hit me up, i just put them on CL.
Next up:
Tint all around
JB1
Houston, Texas
My lil guy barely fits in the garage...
6" BDS w/ 37's
Had to put a low profile antenna on, which bumps the bottom of the door.
you removed the sharkfin antenna for the flat low profile style?
Lifted2wd
depending on the wheel you are running will depend on the lift you should go with. I'm running 37's on a 2wd big horn with a 4" CST lift. I'm also running stock 20's on it.
1quick1
Colorado
Hey I'm in Denver as well. I like your setup. I was wondering a few things.
-What shop you went to?
-Cost for install, wheels, tires?
-What gears do you have?
Reticle918
