Lift on top of level!?
MLX-10
Pa
Can a lift be done in addition to bilsten 1500s in the front and still stock in the rear? I’m looking to do a 2-3 inch lift. Can I just add the lifting spacers on the strut top hats and then get aftermarket upper control arms? I want to fit 35s nicely. 8C9E3BB2-83F4-4101-89A9-601C1D4C7368.jpeg
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Can a lift be done in addition to bilsten 1500s in the front and still stock in the rear? I’m looking to do a 2-3 inch lift. Can I just add the lifting spacers on the strut top hats and then get aftermarket upper control arms? I want to fit 35s nicely. View attachment 528663
No
You can’t install a leveling kit on top of a leveling kit. In theory it’s very possible but geometry is what prevents it from functioning properly. Steering, alignment and suspension travel is what you will feel. The tie rods, cv axles and front differential will get destroyed. Using a bracket style lift (4”+) is what can work with the Bilstein 5100’s but not all kits are compatible. There is a lot of great information on this forum
