Carsten
Does anyone here have any experience with a lifted 1500 5.7l with 35-37in tires and a 2500/3500 Cummins with also 35-37in tires?
I've been searching/youtubing/foruming anything I can get my hands on to try to compare these two beasts performance offroad to try to figure out with of the two would be the best overland vehicle. I can try to reason my way through it as can most of all you, but does anyone have first or second hand experience with both?
My hypothesis between the two is the 1500 may be a little better at rock climbing due to the engine/suspension weight being significantly lighter, however due to it having IFS it is more susceptible to having it's rubber CV housings punctured from debris which would make it become completely useless out in boondocks. On the other hand the Cummins has endless reserves of torque and may be able to just brute its way through most obstacles, and it's axles are more rugged and less susceptible to damage.
I currently have a 1500 5.7l 3.93 limited slip truck, but before I go investing money into a 4K BDS lift with Fox coil overs and the wheels and tires to go with... I may want to trade for the Cummins instead.
Let me know what you guys have experienced when testing out the two, and the pros and cons to both.
