Lifted bigger tires TPMS?
Jkasten619
So I'm going 7" maxtrac with 35x12.5x20 on aftermarket 20x9's. Gonna buy OEM TPMS sensors off ebay? Isnt the tire pressure higher with the bigger tires? Will the sensors work? Or should I just forget the tpms sensors and everything will be ok?
N1ck
Regina Sk
I've been using no sensors since my truck was 5 months old, switch wheels and tires a few times all with no sensors I've yet to see a tpms error light on my dash. Even after swapping clusters for the premium one.
To answer your question, if you do use oem sensors they will need to be reprogrammed to read the corrected tire pressure of the new tires.
BOWERSFJ
Uniontown OH
I've been running 35 x 12.50 E load Toyo's since August. The high PSI's you see on the side are the max rating when loaded. I bought a set of factory sensors on Amazon for $60. I run 43 front and 40 rear. the ride is great, and the sensors work perfect.
