billetgrey
So, you mean do 2 "cheap" oil changes? One to catch/dilute the antifreeze coming into the pan from pulling the heads, then another to start and run it for 15/20 minutes? Or do you mean start the repair without draining the oil, then pull the old oil and run cheap stuff once?Change oil before you even start it,as it's virtually impossible to not have some anti-freeze make it into the pan from pulling the heads,then run it for 15/20 minutes on cheap oil and filter,then change the oil/filter again,then change it again by at least 500 miles,then i'd do it once more at about a 1,000 miles,then switch over to your normal oil change intervals.You just spent a pile of money and labour to replace the cam/lifters,don't cheap out on the oil changes afterwards
How cheap are we talking? I run 5w-30 full synthetic Pennzoil. Should avoid going into synthetic blend territory, or is that what we mean by cheap?
Thank you for clarifying!
