Lifter tick caused by going down hill
Joe Merchak
Hackettstown, NJ
hemi 6.4
I have a 2022 2500 with the 6.4L and 8 SPeed trans. I live on a large hill and for the most of it I am not on the throttle but the trans keep it in a low gear. This makes the engine rev high when cold and causes my lifter to make all kinds of noise. I been lately putting the trans in N and that allows the engine to idle and is smooth and no noise. The engine has 55psi of oil pressure when its happening but I guess it not in the right areas when the rpm go high. Is there any way to stop the transmission from holding the gear and keep the revs so high. I dont need engine breaking, its not that steep. It does not sound good so I can imagine what kind of damage its doing. It does not happen once the engine is up to temp, only cold.
Jane S
That sounds more like manifold bolt issue then the Hemi Tick.
Read my post #44 in the above link for more info.
J
Joe Merchak
Hackettstown, NJ
hemi 6.4
Yea i read all of them, I dont get a tick when started, I dont get a tick when I drive the road in front of my house thats flat. I only get it when going down hill, no throttle input and when the trans keep the motor over 2000 rpm. Remember, when its happening and I switch the trans to neutral, it immediately stops and the engine is smooth and no tick. I will record the sound the next time I go out with a cold motor.
noraa73
