Lighting problem
SeanRamFISH
6.4 hemi
Hi! my brake lights and signal lights work but not my running lights. Took the bulb out and looks OK. Could it be the sunlight sensor on the Dash?
TRK_GANG74
Navy Badge
Va, Hampton Roads Area
Check your ground wire connections for a loose one and check for proper voltage at the light assembly for voltage with a multimeter.
