Lightning bolt
larrygaither
Got home from mowing this morning and started backing my trailer up the drive, slight incline, about half way up it quit moving. Looked at the evic and it showed a red box with a lightning bolt inside the box. Shifted to neutral and back to reverse and same thing, it would not move. Finally shifted to park and back to reverse and no more lightning bolt and truck continued up the drive. Looking for advise about this, oh yeah it is a 2016 ram 1500, 5.7, 8 speed trans. Not sure if this is in the correct section.
14 Lonestar
I don’t know the answer to your question but I’m sure that it explains each icon in the manual.
OCDTech
Louisiana
It has something to do with the electronic throttle,(drive by wire) system, but i don't know what.
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
Wouldn't be too sure on that..........recently discovered my owners manual does not explain the 'tilt in reverse' function of my towing mirrors, and it is controlled thru the evic setup screen.
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
My understanding/experience with the dash warning displays. Lighting bolt is not good. I would get my truck scanned. I have had that twice in my 03. Once for a lifter spring and once for the TB control module.
WilliamS
Tampa FL
Throttle body issue, could be super dirty in there and the position sensor is off. Hit it with a can of electronics cleaner and see if it goes away, if not off to the dealer.
Black W900
Nashville, TN
Wouldn't be too sure that..........recently discovered my owners manual does not explain the 'tilt in reverse' function of my towing mirrors, and it is controlled thru the evic setup screen.
It's in the manual somewhere, I didn't know that I even had that function until I read it in the manual.
huntergreen
Throttle control issue. Sounds like you went into limp mode.
L
larrygaither
Thanks I will probably call the dealer , had no throttle control at all. Nothing should be dirty it only has 15k miles and never driven on dirt roads.
TRCM
USN, Retired
Newport News, VA
Trust me, it isn't......I have searched the electronic manual a few times times.....have yet to find it.
I knew about it from looking thru the menus, and the dealer mentioned it when I was buying.
My guess is you found it the same way, saw it in the menu of the EVIC.
I just went thru again, and searched mirror, tilt, and angle, and none of the hits mentioned the tilt in reverse feature at all.
Firebird
2019 Ram 2500
Were you braking with your left foot while backing up and applying throttle? If you brake and apply throttle together it will cause that fault code.
huntergreen
Hope you are wrong. That would be a really stupid design.
L
larrygaither
Yes I was. Any idea why it would do that?
Firebird
2019 Ram 2500
The throttle by wire system can't handle it for some reason, found it out from my dealer on my Cummins. I had half a dozen stored codes from breaking with my left foot on that truck. I don't remember the technical reason on why it causes a fault code, but it does.
SYKRAMMAN
Banned
Jersey shore
06 Mega
That’s so weird, I wonder why they engineered it that way.
averageguy
Belleville Mi
hemi
My guess would be to stop people from being able to melt the back tires off by lightly holding the brake and gassing on it. Around here referred to as a brake torque, brake torqueing it.
TerraNewf
NL, Canada
I recently backed my boat up a steep incline with no issues. But can't remember if I applied the brake while doing so.
Administrator
Part of the "safety logic" for the electronic throttle is to see if the brakes are being applied. It stems around the people claiming their car accelerated through their garage with their foot on the brake.
The truck has a Hill Start Assist(with the 8.4 radio you can turn it on/off) that will hold the brake temporarily or until you step on the throttle when the truck can roll backwards.
SYKRAMMAN
Banned
Jersey shore
06 Mega
Over here it’s called being a moron and ruining your truck. Well that’s good then, so in ten years when I’m ready to buy a 2018 at least I’ll know it wasn’t a burnout truck. But wait, I see people doing brake stands all the time with their new trucks , are these people that are layin rubber just ignoring the cel’s?
